1 - 7 of 7 Posts
Home of The Whopper
Anyone know if the Federation Fighters heads are compatible with DML. BBI, HT or any of the other bodies out there? I wanted a Stone Cold sculpt for a bash I want to do, thought the ACE one was fine until I noticed the double chin, so I've been thinking of getting a Federation Fighter figure for the head...
The Mighty Boosh
I picked up a cheap animatronic type figure and used that HS mated to the lower part of an old TUS or BBi HS
(This is obviously before it's been painted so you can see the join line.
Home of The Whopper
A friend of mine has that figure, I don't think he wants it though so I'm going to see if I can get it, that's a great idea, and that sculpt is far superior to the F2 figures, thanks...
Da revolution is here!
I did the same with a similar wrestling figure, not from this series. Here are some pictures of it in case they can possibly help you transplanting it:
For transplanting the head, I simply cut around the head on the Power Team body where I though the new head would be able to fit over it. After I had both heads off I put some clay into the Wrestler head, and then mounted it onto the PT body. If you want to speed stuff up, you can apply glue to the edges of the neck and head (Warning though, some of this may drip down and permanantly stay on the neck where your able to see it).
Here are some pictures of the PT head that I err... Decapitated:
(I apologize for such crappy pictures!)
1 - 7 of 7 Posts
