Re: WIP 1/6 Dragonborn - Skyrim
Looking very cool so far. Can't wait to see more.
What did you use for the metal studs if I may ask?
Thanks
for the larger round ones, I used push pins called Brads. They are about 4-5mm in diameter and have 2 pins that fold out either side at the back. Just pushed them through and folded them open and glued to keep in place. For the smaller metal studs on the shoulder strap and circular piece on the chest I used sewing pins with heads, pushed them through then cut the end off at the other side.
Another update. Using Dastan's head for now, so he doesn't look as headless. Sculpted a shield, and 2 bronze plates for the belt and chest armor. Just carved some simple designs into it to give it a bit of shape, and made the shield look damaged.
Still planning to give the guy an axe, bow and quiver, as well as some potion bottles and other tidbits hanging off the belt.
