1 - 20 of 21 Posts
I made the cloak squeezed a phicen into SS cat womans body suit i just need to make a belt for her . Hope you like it.
It doesn't come with a battery. It is voice or sound operated. Snap your fingers to light her eyes. They have a 5 second time to stay on.
Thanks for looking.
This is just a great figure. Congratulations!
I have also been eyeballing these Sideshow Catwoman jumpsuit for a custom. How would you describe the fabric this jumpsuit is made of? Is it some rubberized material like Hot Toys' Selina Kyle? That jumpsuit being rubberized has a very short lifespan as a result, and in my figures I am always looking for a long lifespan. This particular Sideshow Catwoman jumpsuit seems to have some lines made with plastic that run along the legs and on other parts of the body. Is that plastic that can last long?
Thanks,
m.
Thanks,
m.
The fabric is sturdy. The lines are rubber. I haven't used it much since I got it. But it could have easily torn on her because of the silicone fills it out around the calves and wrists. The last body I used was a hot toys. Because of the weak hips on Sideshow. Back then it stained that body. I want to say it feels like canvas for texture. But I know it's not. It's more nylon/polyester.
OK, thanks for your answer.
So, you say that the fabric is sturdy, which I understand means that it is not rubberized. Just plain, durable fabric. Correct?
Lines being made of rubber is worrisome, but there's nothing we can do about that. Does the rubber feel sturdy, at least?
Canvas should not be stretchy. Is that jumpsuit stretchy? Even if it was, it doesn't seem to be very stretchy, because you say that it can barely wrap the Phicen body. Did you try to stretch the jumpsuit somehow, so that it become wider before putting it on?
Have you also tried putting the suit in hot water with vinegar? That should remove any excess dye from the fabric and keep keep the jumpsuit from staining the silicone.
Thanks,
m.
Thanks,
m.
Yes its durable enough to get on the body. Unless you rub the lines every chance you get they'll probably come off. Once you put it on it stays put. Pose it and you'll never have to worry about it. It dose have a good stretch to it. Enough to be able to pose in. I don't worry about stains. If it dose stain, I just buy a new one anyway. or I use an old one that wont be used much. I have a bunch of Phicen bods.
Discussion Starter · #10 ·
ok before you go out and buy this head sculpt the battery doesn't last very long two day old battery and it is dead already.
Discussion Starter · #11 ·
Well I got her some armor and started to get them ready and saw the zipper had split on her upper back. Oh well it was an idea. Time for another one.
I am glad I continued checking this , I could not see the pictures at first. The red eyes are cool and I like the rest of the look as well.
Thanks for looking.
What Phicen body did you use, the one that broke the zipper?
Thanks,
m.
1 - 20 of 21 Posts
