yes the cover is made like 1:1 with the wiggley bits that flip inside.justin_g said:AND - that's on Toy Soldier headsculpts which are smaller than most others! :cry
How much does the cover go up the inside of the helmet - would it be possible to remove it and put it on another manufacturers M1?
Thanks for checking - do you think it could be made to fit over a DML or DiD M1?Bravo_2_Zero said:yes the cover is made like 1:1 with the wiggley bits that flip inside.
you can even fit the helmet inside a DML normal M1 :sadshake
seems TS took the size from a DML fibershell rather than the outer :rolleyes
it should but the sides where the chinstraps are located, the cover is cut round just enough to fit the straps through. This could mean when added to a larger helmet the cover will show more steel pot than it would on TS one.justin_g said:Thanks for checking - do you think it could be made to fit over a DML or DiD M1?
