1 - 3 of 3 Posts
Arhian Pirate
In the years after the third Arkhorian War, hordes of pirates, and mercenaries roamed the savage seas, their swords serving no cause but themselves or the highest bidder. Across these bloodstained waters rode Arhian and her lover, Captain Ras, a proud and fierce pirate couple, their guile and wit as cutting as their blades.Storming through an age without heroes, she claimed it for hers and cleaved her way into legend.
Packing List:
① 1 x head sculpt
② 1 x TB League female seamless body with metal skeleton
③ 3 pairs x interchangeable hands
④ 1 pair x armlets
⑤ 1 pair x forearm armors
⑥ 1 pair x shoes shafts
⑦ 1 pair x shoes with feet
⑧ 1 x sword with sheath
⑨ 1 x dagger with sheath
⑩ 1 x abdomen armor
11 1 x headscarf
12 1 x necklace
13 1 x one-piece dress
14 1 x belt
15 1 x base
First look at the box, front and back and sides.
the contents. 2 layers, with the base on the 2nd layer.
And there is all of the contents. The HS seems familiar. And the body is S22A, I believed. The weapons are not metal. Looks good thou.
This is what took up most of my time. You have to string up the armor yourself. When i tried putting the string on, i found that the end of the strings weren't harden, so i have to do it myself with superglue. Hence it is easier to put the strings through each very small holes. Luckily i only need to do one side, as the other side is fixed.
Afterwards, i tried putting on the waist armor through the legs, with the strings stretching the widest gap possible. A bit of a hassle, but finally get it done, and a knot is tied after pulling the strings to close up the gap.
The other accessory that needed attention is the necklace. It is comprised of one necklace, not 2, with 2 seperate white tooth ornaments. I put on the necklace by wrapping the necklace around the neck twice, before putting on the HS. After some adjustment, i tied the knot of the necklace, and it's done.
The red headscarf was shipped inside out. So i merely twist the headscarf over, and secured it onto the HS.
The rest of the accessories were easy. A complaint on the feet, though. It did not come with the high heels feet, so certain posture a female figure can pose, cannot be done. And in case you are wondering, there is a strip of black undie with the figure.
The base. No supporting stand to hold up the figure. I have to rest the figure onto the background wall in order for it to stand properly.
1 - 3 of 3 Posts
