Hello,
I've ordered from Mister Art numerous times and haven't been disappointed yet. Dick Blick is another source
www.dickblick.com/ . They're pricier than Mister Art except when there's a sale. I use Blick for my painting supplies (especially water soluble oil paints which along with actors paint, acrylics and water colors works well with polymer clays) and Mister Art for the sculpting things (like the silicon molding material and permastone).
In general, I agree with Tony regarding the polymer clays like Sculpy or Fimo. A few tips though for the budget conscious about smoothing and crack repair. The plasticizer/diluent for polymer clays works great in general and for restoring tired clays specifically- the dry crumbly stuff that no amount of kneading helps. Put the tired clays in an airtight bag or container with some diluent, mix as well as possible and set aside for about three weeks. Most of the time, the polymer clay can be worked again. For smoothing rough pieces or fixing cracks in unbaked polymer clays- clay diluent, lighter fluid, 90% rubbing alcohol, acetone, and waterless hand cleaner all work. For fixing cracks in baked polymer clay, one of my books recommends using acetone to remove the crack but I prefer to lightly heat the piece, scrape down to the crack, wet with hand cleaner, fill with the clay and smooth with hand cleaner.
As for the epoxy clays, I've used those but mostly for filling and adding features to existing sculpts- I don't have the skills to make a sculpt from scratch using that stuff- but for fine details Magic Sculpt and Apoxie Sculpt work well. You might want to check Jim Bob Wan for info on epoxy putty/clays- he had a section on it at one time which I read extensively. Some of the people on this board did amazing things with the cheaper version of the Magic/Apoxie Scuplt- plain old Plumber's Putty- but that stuff smells to high heaven and is extraordinarily messy.
As for casting, for health reasons- my own- I don't use resins... I use water soluble "plasters" like permastone. If you want to try that out, you can purchase small inexpensive casting and molding materials from American Science and Surplus
www.sciplus.com/ . Look for Instamold and Permastone and buy a couple of plastic containers for about $1.00 the total cost for this starter kit would be under $25.00.
Mike .
