I've used Aves many dozens of times on projects & I've never had any trouble with it drying completely until recently. I sculpted some hair onto a figure & parts of it are completely dried and solid, but several areas are still not dry & solid even after about 3 or 4 days.
It could be a result of many different things, but right now I'm just trying to figure out a quick and easy solution. Is there something that I could use as a "fixative" of sorts or some type of method to harden it so it can be painted? It's just a few small areas here and there that are still kinda soft.
Same here but maybe if you coated the area with super glue? I've never had the tacky problem you've mentioned but I've used the superglue over Apoxie Sculpt that had not set up yet and it turned out fine. Best of luck.
FRED
