1 - 7 of 7 Posts
Hi all,
I just received the Play Toy Bride Killer version 2, my first Play Toy figure. But its neck looks strange. I post some pictures for you to give a look. And please tell me if this is normal for Play Toy body or its neck connector is too low. If you have this figure could you post some photos of yours? Thank you.
Brand 74
Sometimes that socket is not up in the head as it should be. I've came across this with a hot toys head once the socket had about another 1/4 inch to go up in the head. A good press should do it.
I trim the ball about halfway, using a coarse sandpaper. I do it with some third-party male bodies with Hot Toys heads.
AKA Nigel...
I've been coming across this problem quite a lot lately.
Get a pair of needle nose pliers and pull the insert out of the head and then try and fit it over the neck post, you may have to heat it up first. Then see if you can fit the head over it.
Some times it works sometimes it doesn't.
You can always discard the insert and use hot glue instead.
1 - 7 of 7 Posts
