I scored a TUS OH-6 last weekend at a military show for a great price. I knew it's not fully 1/6 scale, but I figured I could work with that. TUS made several versions of this chopper, much like Hughes Corp. did with the real thing. TUS seems to have simply applied different paint jobs on a single model. Whatever they were modelling, although the exterior is pretty good, the interior is some totally different version from the one used in Vietnam.
I've used a HT Slim for the pilot which helps a lot. I'm also going to remove the double bulkhead between the cockpit and the crew compartment -- that will give the cockpit a little more depth.
Okay, so here's what I'm aiming for:
And here's what I have:
First thing is to take the model apart (there are a lot of screws!) and remove both halves of the bulkhead. I'll keep the pilot's side and discard the other.
Chop, chop.
The opposite side of this piece is indented where the seats are, so i'll cover it with a thin layer of sheet styrene.
Here's the backside cut out with the first row of rivets in place. I am cheating with these rivets - they're bigger and fewer than on the real thing but at least they match the size and spacing of the rivets on the exterior of the chopper.
Test fit. Yes, I'm working on a new floor too, but I'm not sure if I'll use this one that I made, or do a better one. Anyway, on with the bulkhead.
Finished rivets, and first coat of primer.
Adding electrical conduit and access plate.
That's it so far after about 2 days. Thanks for looking!!
Chop, chop.
