One Sixth Junkie
Hi Dave,.....just a suggestion.....!!!by the moment that ilearn that you are a teacher to mount and dismount heads from body...(of action figure....obviously...)could you suggest me the correct way to detach a bobcat head and neck from the body, to mount on ht body???'I mean ...when i detach a dragon body from head, i use the hair phone, with hot air, on the neck of the head...but with the bbi g3 body (or maybe with ht heads)in which way i must do ,to evit to broke the neck......!!!!I could use the hair phone too?thanks Mario.
I've popped bbi head and neck assemblies off before without breakage, but to be sure, it might be best to heat it up a bit. My choice would be a large-mouth cup or bowl with water brought to a low boil in the microwave. Dunk it head-first up th the shoulders and let it set for a little bit. Carefully hold over a paper towel and give it a slow, steady pull.
super hot outside
Like pukingdog said, warm/hot, but not, boiling water is the key. I've done it many times without breaking the neck joints or the head.
Hair dryer (or as he said hair phone :D) sometimes won't work because the heat can't reach the inner part of the neck.
Mandoll withdrawl
Lol Dave, until I read it all the way to the end I was seriously concerned about you :p
Hope they've given you good suggestions M.
marios1
thanks
Thanks Dave, and thanks to Pukingdog for his suggestion...i ll do so!!!Yes Doly, i couldnt use hair phone...to detach heads from body....but i could use it for speak with them...eh eh eh!!!!Thanks to you too!!!!Mario.
