The rest will flow
I would take this over any static resin replica, hands down.
Matrix Limited Edition Custom Alien Pulse Rifle Airsoft AEG
Features:
Heavy Weight, Solid Construction.
Aggressive look and feel
Custom Thompson 190 round hi-cap magazine included and hidden away
Working LCD Ammo Counter (Counts down from 95 to 0. Each 95 round count down is essentially half a mag!)
Battery hidden away in "Shotgun" compartment
Retractable Metal Stock via One-Touch Button
Realistic Dummy Shotgun Shell
Great for in-game use or as a collector's piece
Full Metal, fully upgradeable advanced Ver. 6 gearbox with reinforced internal parts
1:1 Scale Alien Pulse Rifle as seen from the movie
The Sixth Element
I got one and it is awesome.
Some of the metal parts do rattle a bit ,but there some easy fixes using self adhesive foam strips to shim the parts.The shroud is put together tight so go slow and easy when taking it apart if you're going to modify it.Just a little weathering with paint makes it look really good.
It's a re-release of the G-P kit from the 90's so anything desinged to work with that kit should work with this gun,plus back then it cost twice as much and you had to build it yourself.:bravo
Brit Basher
Does anyone know if this is available in the UK?! Can't find it anywhere and am absolutely dying for it!
The Sixth Element
Evike ships internationaly by Express Mail Service.
They have a section on shipping internationaly on their FAQ that gives more info.
Good luck.:goodluck
