21 - 23 of 23 Posts
171 Humbrol proved to light, I bought 805 Koper from "Amsterdam Acryl"
But with a tad of black from left over Tamiya acrylic paint.
Its not perfect, but it blends in fairly well with the rest.
Anyway, I finally got the 3D printed pieces back from the printer, it took him 20 times or more to get it right.
The pistons were printed in 3 parts: 2 halves of the body and the shaft itself.
The piston printed here, is the longer one, so you will have to cut the body shorter if you need the shorter one and full up the side where the shaft slides in and out...
I also lost an Antenna, and they managed to print the head, but not the shaft because its too thin.
So I sued a toothpick instead :)
Some pictures.
here everything is attached to the flaps:
I have all the parts in a 3D files (.stl extensions), so you dont have to scan anything, just print it on a 3D printer.
I did have to sand the halves and the opening for the shaft so it would slide smoothly.
You can do a better job sanding the actual piston, because you can see on mine, the finish isnt very smooth, but again, in the bigger picture, it blends in well.
I will post picture of everything installed on the Tumbler somewhere begin March....
I ask 5$ for all the files, send me a message or PM if interested.
Hi bro, i´m interested in the 3d files for all the tumbler, please contact me to close the deal. thank you
Discussion Starter · #23 ·
5 USD for:
  • long piston in 2 parts - 2 halves in the length of the piston (you have to cut yourself to get the short version, as I did)
  • piston valve
  • tip of the antenna (antenna body I made out of a toothpick myself and cut it slimmer)
Those are 4 pieces in total for one complete long body shock with piston and the tip of the antenna.
Payment via paypal.
PM me for my paypal.
thx
21 - 23 of 23 Posts
