1 - 2 of 2 Posts
fit the leggings on the nude legs. Once it is all tighted, fit the boots into feets and then gingerly pull the leggings near to the boots. You may be able to fit the legging sole straps under the boot soles.
Once it is finished, put the trousers into the legs and tuck the bottom of the trousers legs into the leggings gently. Once it is tucked, pull the trousers to give it an realistic baggy look.
Hope this helps you
1 - 2 of 2 Posts
