Sorry to hear you had troubles, best of luck with salvaging your projects as well. I can definitely relate from having 1/6 finishing issues with the Dremel, regular paint, the Xacto, etc. So far my experience with Dulcote has not led to any mishaps ( thank God ) I have used it in several light coats, applied with a quick fanning motion - I think it's an airbrush technique I read about a while back, but seems to apply well to Dulcote. I agree with the above that shaking the can - even between spraying - and applying the Dulcote at a consistent temperature, in a moisture free environment can help. I have also placed spray cans ( although paint in this case ) in warm water to heat the paint to room temp. That seems to help with viscosity and dry time. Might be a good technique for the Dulcote as well. Again, best of luck with salvaging the stuff you worked so hard on.
