AKA "ChiliDoug"
In my experience, the newer DID heads will fit without modification on to an older style Sideshow body. With a little modification, a DID head will fit on to a dml style body. All you have to do is shave or cut off about 1/8 of an inch from the bottom part of the DID head/neck area and it will fit on to a dml style neck post. The problem with DID necks is that they are too thick for dml neck posts, so they will just pop off. The 1/8th inch shaving needs to come from the inside of the neck, in order to make it thinner. then it will fit, no problem.
Therefore, a DID modded head will fit on to a Barrack Sgt body, as they come with (among others) a dml stlye neck adaptor. Hope that helps.
doug
