1 - 20 of 158 Posts
Care TOYS 1:6 Kunoichi 铠儿模玩 1:6 女忍者 飞鸟 &地台石灯场景 くノ一(Kunoichi)
铠儿模玩 Care TOYS 1:6 女忍者 飞鸟 &地台石灯场景 くノ一(Kunoichi)
Manufacturer: Care Toys
厂商 :铠儿模玩 Care Toys
メーカー :Care Toys
Product name:Kunoichi Asuka
产品名称:女忍者 飞鸟
製品名:女忍 あすか
Specifications 1:6(about26×5cm)
规格 1:6(约 26×5cm)
サイズ 1:6( 約26×5cm)
Others:
其他
その他
※It's the sample in the pictures. The actual goods might be slightly different, please understand.
※照片上是官图样品。实际的商品会有稍许不一样的地方,还请您了解。
※画像はサンプルです。実际の商品とは多少异なる场合がございますのでご了承ください。
Commodity Description:
商品说明:
商品仕様:
女忍者人物介绍:
飞鸟 (飛ぶ鳥 あすか)
所属:
伊贺派
Belongs to:
Iga fraction
身份:
忍者(等级 中忍 实际作战的现场指挥官,忍术超然出众)
Identity:
Kunoichi (grade: Chuunin, actual combat field commander, excellent Ninjutsu)
故事剧情:
身为伊贺派首领百地三太夫嫡传弟子的女忍者 飞鸟,目前在组织内担任中忍的头衔,是带领下忍们在一线执行战斗任务的指挥官。这次受命在兴福寺山门外执行秘密任务。
Storyline:
As the leader of Iga fraction, Momochi Tanba elder disciple, the female Ninja Asuka currently hold the title of Chuunin in the organization, is the commander who leads lesser Ninja perform combat missions on the front line. This time, she executed a secret mission outside the gate of the Xingfu Temple mountain.
女素体:
铠儿模玩 (Care TOYS) 全新研发亚洲女性娇小身材女素体。
鉴于目前市场都是身高约1.75米以上等比缩小的欧美高个丰腴型身材的女素体,为符合产品系列人物形象,铠儿玩具 (Care TOYS)专门研发了这款 实际身高约为1.60米等比例缩小1:6比例的 瘦削身材娇小亚洲女性素体。素体采用硬PVC材质,(跟HT同样的材质)(正式产品大货会进行乳房等部位的体妆上色)。新女素体兼顾外型美观及高可动性,关节松紧适度,牢固耐用.不会爆胶(无胶可爆),配备五对手型及连接器,还有增高小腿连接器。足以应对正常摆造型的最实用手型需要。
Female body:
Care TOYS has developed Asian women petite figure female body recently.
In view of the female bodies in current market are all about 1.75 meters in height scaled down western body with a plump shape, to meet personalities of series product, Care TOYS specially develop the slender petite Asian female body, the body to the actual 1.6-meter-tall female ratio is 1:6. The body is made of hard PVC material (the same material as HT) (The formal product will carry on the body make-up on breast and other body parts). The new female body has beautiful appearance and high mobility, and the joints tightness are suitable, firm and durable, will not burst glue (without glue), equipped with five opponents and connectors, as well as an elevated calf connector, to meet the most practical hand shape needs of normal styling.
特别值得一提的是,为了让1:6的玩具更加有趣,我们研发了第一代1:6女性可动手型。最细1毫米的关节连接器对工艺及设计,装配都要求很高。一对手近百个零配件,我们不辞辛苦为了让大家高兴,我们乐于挑战跟尝试.
女素体可以摆的造型运动幅度范围领先于市面上的同类产品,头部跟手脚连接器通用于HT等主流女素体,配件互换性良好。厌倦了满眼的丰乳肥臀大洋马女素体了吗?想要个娇小可爱的青春少女素体换换口味吗?不管是把玩还是摆柜这款新女素体相信都是好的选择。
It is particularly worth mentioning that, in order to make 1:6 ratio toys more interesting, we have developed the first generation of 1:6 female movable hand type. The smallest 1 millimeter joint connector requires a high degree of process, design and assembling. A pair of hands have nearly 100 parts, we try our best to make everyone happy, and are willing to challenge and try.
The styling and pose of the female body are superior to similar products on the market, the head, hand and foot connectors commonly used in HT and other mainstream female body, with a good accessories interchangeability. Are you tired of western plump breasts and buttocks female body? Do you want a petite and lovely young girl body for a change? Whether to play with or put on the cabinet, this new female body will be a good choice.
头雕:
铠儿模玩特意请一流头雕师制作了一款美丽的亚洲女孩头雕,还做了妙尼姑头(秃头),短发植发,以及长发束马尾(龙尾发),披肩发 四款可替换发型供大家选择。到时就可以有四款造型替换着玩了。
Head carving: Care TOYS specially invited excellent head carver to produce a beautiful Asian girl head, there are also four hair styles of nun head(bald), short hair, long hair ponytail (dragon tail hair), shawl hair for everyone to choose.
筒笼手:
篭手 在日本甲胄中指的就是手臂装甲。材质为纯铜片加上纯铜环纯手工连接。之后喷烤漆制成,视觉效果接近真实笼手。一千多个大大小小的金属环纯手工串起,五十八块金属板,每片都需要捶打定型,我们相信,我们的诚意大家看得见!
Barrel Kote: Kote in Japan refers to the arm armor. Material is pure copper, coupled with pure copper ring, hand manual connected. After spraying paint, the visual effect is close to the real kote. More than 1000 metal rings handmade strung, fifty-eight metal plates, each piece needs to beat the stereotypes, we believe that our sincerity will move everyone!
打刀:
武士刀,忍者通常使用直刃忍刀,而飞鸟的刀是师傅百地三太夫所赐,故此一直随身使用。打刀名为"竜鸣一文字"出自名匠之手,非常漂亮。
大家对市面上的1:6塑料刀跟压铸翻模的粗糙铅锌合金武士刀腻烦了吧?铠儿研发的这款古武士刀从材质到形制都参考1:1日本刀制作,刀身采用不锈钢刀条由手工研磨抛光,刀镡等装具采用纯铜制作,刀柄装饰龙头(柄头)为金属。目贯,切羽,刀镞等等一应俱全,是1:6兵人厂家目前出过的日本刀里非常精致的。
Katana: Ninja katana, usually use straight blade katana, and the katana of Asuka was sent by her master Momochi Tanba, therefore she carries it with one. The name of this katana is Long Cry text, was made by a famous artisan, it is very beautiful.
Are you get tired of the 1:6 plastic katana and die-casting rough lead zinc alloy katana on the market? The katana developed by Care TOYS refers to 1:1 Japanese katana from material and shape, the blade adopts stainless steel blade by hand grinding and polishing, Dao tan is made by pure copper, the decorative dragon head (handle) is made of metal. In addition, there will also have a traditional handle can be replaced when sales. Menuki, Seppa, arrowheads are available in all varieties, is a very exquisite Katana currently produced by1:6 Ninja factory.
*(增加)刀柄龙头有普通传统款样式柄头替换件
*(add) The dragon head handle has an ordinary traditional style replacement.
短刀:
名为"石榴切",是飞鸟随身携带的护身短刀。也是按照真实短刀制作的,刀身采用不锈钢刀条由人工研磨抛光,刀装具采用纯铜制作.是目前兵人厂家出过的成品里非常小巧精致的。
Dagger: also called "pomegranate carving", is the flack dagger of Asuka, also made according to the real dagger. The blade adopts stainless steel blade by manual polishing, fittings using copper production, is a very dainty dagger currently produced by Ninja factory.
刀架:
实木制作的刀架。
blade adapter: made of solid wood.
卷轴:
记载了伊贺派不外传的忍术奥义的武功秘籍。
Scrolls: recording the anonymous Ninjutsu martial secrets of Iga fraction.
面具:
般若(女鬼)的鬼面具,佩戴上用来威慑敌人 隐藏自己身份的道具
Mask: Prajna (banshee) ghost mask, a prop used to intimidate an enemy and conceal one's identity
勾绳:
铜质的爪勾,用来攀登高处或运送物品用。
Hook rope: a copper claw used to climb high places or carry goods.
苦无:
苦无 可作匕首用,也可作飞刀用,配备了两把。
Kunai: can be used as a dagger, also can be a fly-cutter, equipped with two.
手里剑:
类似飞镖,十码之内可百发百中,配备了三支。
Hand sword: Like darts, can be shot in ten yards, equipped with three.
锁镰:
是日本古武术中独特的奇门兵器之一,其功能长短互配,软(兵器)硬(兵器)合一,攻击范围兼顾远近距离。
Kusarigama: くさりがま
It is one of the unique special weapons of ancient Japanese Wushu, with both long and short functions and attack range, can be both soft and hard weapon.
忍弓箭套装:
具有锋刃的一种远射兵器。弓一把,箭三支,箭袋一个。不同于日本标志性的长弓,忍者在密林中穿行需要便于随身携带的忍者专用短弓,用以射击敌人,射出攀缘的抓钩,放火箭等等。
Bow and arrow suit: a long-range weapons with blade. A bow, three arrow, a quiver. Different from Japanese iconic longbow, ninja needs special Ninja short bow when in the jungle for easy carrying, to shot the enemy, shot the hook for climbing, or fire arrows and so on.
忍者服:
内穿的连体网衣,上衣,挎(裤子),束腰,护手,护腿,围巾,足袋(鞋)是忍者整套执行任务时穿的夜行服
Kunoichi clothes: inner siamese mesh clothing, jacket, trousers, corset, arm guard, leg guard, scarf, foot bag (shoes) is the whole set of nocturnal suit worn by ninjas when they perform tasks.
场景地台:
Scene platform:
兴福寺山门外的石灯&石阶&地藏菩萨深秋时节场景 (附有干花植物包,可以参考图上自行安排位置) 石灯可亮灯,石灯及石像可以移开,(地台单独发售)适合搭配任何日本风格人形。
Stone Lamp &stone steps &Ksitigarbha scene outside of the Xingfu Temple mountain gate in late autumn(With a dried flower bag, you can refer to the map to arrange their places ) Stone lights can be turned on, stone lights and stone statues can be removed, (the platform sell separately) suitable for any Japanese style humanoid.
关于铠儿模玩 (Care TOYS):
About Care TOYS:
2016年成立的品牌 致力于制作古代世界各国铠甲类1:6收藏级可动关节人偶模型,我们关爱玩具 目标是制作有价值的玩具。铠儿承诺 永不复刻!
The brand established in 2016, is dedicated to manufacture the 1:6 collection type movable joint galatheidea doll model in the ancient world. We care for toys and aim to produce valuable toys. Care TOYS promised never remastering!
Re: Care TOYS 1:6 Kunoichi 铠儿模玩 1:6 女忍者 飞鸟 &地台石灯场景 くノ一(Kunoichi)
wow... really like the body and the movement range... :clap
Love the HS, but the naked body photos remind me, slightly chillingly, of Gollum.
Discussion Starter · #4 · (Edited)
Thank you for your appreciation. This body is developed by us.We're glad you like it:applause
Thank you for your appreciation. This body is developed by us.:hifive
We're glad you enjoyed it:dancing
That looks mighty fine
I want those articulated hands!
Price will be the deciding factor for me. I know I will eventually swap out the body, so for me this will be like a accessory kits. But I love what I see
What a fascinating figure! I like the different hair options, and the body has really nice range of motion, yet still looks good. I have only one set of hands with articulated fingers, and they were made ages ago by Volks. These look a lot better. I really like the head sculpt as well.
Sure hope these become available soon!
That's actually quite nice. Color me interested.
Discussion Starter · #18 · (Edited)
Thank you for your preference for our accessories package. I agree with you that price is an impossible topic. We racked our brains to achieve as high a quality as possible at the lowest possible cost. Our goal is, when you buy a doll, you can't help but exclaim: "hell, it's really worth it."":goodluck
Discussion Starter · #19 · (Edited)
Love it! Sure buy of price is right!
We hope the price as low as possible, [edit] we have seen, the main high cost in a large number of manual processes, complex assembly, we will continue to work hard. Because what we want to do is valuable Collectible dolls.:thumb
1 - 20 of 158 Posts
