1 - 15 of 15 Posts
My 1/6 Doctor WhoMatt Smith figure fell and hit the ground the other day. When I picked up, his nose looked smashed in prson.
I showed the damage online, but it doesn't show well on the camera. That said, is there a way to fix the dent? Would putting it in boiling water help the nose get back in place?
Resisting Evil
If you can pop the head off the body, and if the head is hollow, you should be able to get a small flat head screw driver in there and pop the nose out from inside.
Heat it up with a hair dryer till it's squishy and it should go back to the right shape. I'd worry that boiling water would damage the paint.
Schizophrenic Modeler
Do as Rogerbee has suggested and use a hairdryer, or if you don't have one, hold the head under hot tap water (not boiling), and use the end of a small paintbrush on the inside to help press the nose back into place. The hairdryer will work best though, and once it's back to the way you want it, you can set it by immersing the head in cold tap water.
David
Thanks for the tip, guys.
The head is as solid as an HT head, so I don't think poking in the inside would help, though I will use the hairdryer trick since I do think I remember people successfully fixing flat, solid noses.
Resisting Evil
Just be careful with the hair dryer....it can turn plastic into a runny puddle real quick like if you leave it in one place too long........then you'd have Quasimodo....
You must have a pretty powerful hair dryer then, I've used hair dryers for years and have never had that happen.
Guardian of Hades
He's a "Man's Man" and uses a heat gun paint stripper to dry his hair, and a wire brush to clean his teeth.
There's no wimpy hair dryer in his bathroom and if you go to his toilet, there's a roll of sand paper to wipe yourself with.
"roll of sand paper."
Where? I need one.
Resisting Evil
Thanks for the "man's man" plug, but I'm really trying to play that down.....it's obviously making lesser men sad.........:wink
But seriously, plastic has been melted by hair dryers; I was only trying to be helpful to the guy.......if that's ok with everyone......:think
Guardian of Hades
:wink I'm only playing mate, no offence was intended.
1 - 15 of 15 Posts
