1 - 7 of 7 Posts
Im not as creative or artistic as many of you, so I need some guidance. I am working on a Norwegian SOF bash. Their version of the DCU doesn't look much different from ours. I think the brown spots are just bigger. Would there be any way to customize a set of DCUs to look like them? Any help would be much appreciated.
Ain't it Cool?
Well, to me it looks a lot like the French Desert cammo that Reload Action.com put out in 2006 (http://www.reloadaction.com/fack.htm). However, the pockets are different on the French uniform. The good news is that DCUs are cheap now and so painting then and making a mistake would not be the end on the world. I think you can make it work by painting it yourself. However, getting the right paint will be the key. Here is another ref location for you http://www.militaryphotos.net/forums/showthread.php?t=1173.
Stall thanks a bunch brother. The frech cammo does look pretty close, and your reference pic is a lot better. Do you have a suggestions on what paint to use and will it look obvious? Thanks again.
1 - 7 of 7 Posts
