1 - 19 of 19 Posts
1/6 Scale Lucifer Clothes Set For Fiona Valkyvia Chronicles LXF1702 12" figure
Features:
(Valkyria Chronicles) Fiona is created to be a magic style-based original character model after referencing several domestic and foreign CG illustrations and the original game. These armors were specifically designed for KT004 head and Tbleague silicone body of the SI 2d model, so that they demonstrate the tailored fit between the parts. In addition, we utilized the exclusive use of the platform with the model to further project the harmonious combination so while playing with the model, it will display intense static prospect.
Note: This product does not contain the body and head (recommended with the use of Tbleague/ Si 2d silicone body and KT004 head model)
Packing List:
Armor Type:
Headband/1
Scarf Armor/1
Chest Armor Piece/1
Removable Shoulder Armor/2
Armor Arms/6
Gauntlets/2
Thigh Armor/2
High Heels Battleboots/2
Crotch Protection Piece/1
Leather Pieces:
Sexy Bodysuit / 1
Leather Sheath / 1
Black Stockings / 1
Leather Back Piece / 1
Weapon:
Cross Sword (Metal Plating Process)
Sword sets
Platform:
Main Scene: After the rain relics scene
Accessories: European Stairs, Small Hare
When I received it. I was a bit surprised...why such a big box? Upon checking online, I realized there is some base included, and hence the price...I wish I could order without the base...
The product was quite well packaged...with custom protective foam to protect all pieces...so no damage or what so ever to any of the items.
And...contents. There are a total of 3 layers...the main armor, the sword and the European Stairs, and the base, with 2 animals. Of course, I won't see any body or even a head sculpt...they are not in the product description...
the contents of a little package. It contains the fabric clothes (if you can call it clothes!), the stockings and a Leather Sheath.
so, I decided to use a TBLeague S23B. It's has defined muscular tone to the abs and the arms, which i think should be for a woman warrior, and a toner body to fit one of the HS which I will be using.
And...
There is NO MANUAL!!!
There is some learning curve to how to wear the "sexy suit" onto the body...Definitely legs in first.
Now, the suit is quite tight...I was in fear all the time, that the suit might just snap!! I have to cross the legs in order to squeeze the, em, bottom wear onto the buttocks of the figure. Then, I have to bend the body in order to put the upper part onto the neck, not forgetting to cross it first. And was I lucky to go with S23B! It has a mid bust size, which makes it easier to put on such a tight, sexy suit! With some adjustments, especially to untwist the suit, it's finally done. Whew!
Like I mentioned, there is no manual, and the product preview pictures on the net are also not so clear, I ponder a bit to how to put on the leather sheath. Upon studying it, I figured, it should be worn thru both arms. I noticed a slight angle of the sheath, so i decided the angle to how i should adjust it.
And the straps are very tiny! I have to use a pincer to fasten both straps. Took a while, but it's done!
I decided to start on the legs. However, to my surprise, the stocking isn't right! It's only mid length, and seems to only ride on the thighs! I studied the online preview pictures again...it's not the same!
I decided to come back to this later.
I decided to wear the shoulder and arm armor. It's not difficult to put on, but i struggle abit, as the S23B has more muscular arms. And...the black colored arm fabric wear that was featured in the preview photos, are absent. So...I tried to squeeze the arm thru the armor, some hassle, but finally done!
I went back to the legs, and...It took the majority of my time for this figure!! Let me explain.
Firstly, (as there isn't any manual, or pictures printed anywhere), I decided to roll the Half-stockings all the way to the thigh area. Then I put on the Thigh armor, and...it looks good! I did realised it is easier to wear the thigh armor, pushing it up the thigh along the stocking, which makes it smoother to slide along...
Then I decided to roll down the extra length of the stocking to cover the knees. After which, when i decided to put on the Leg Armor...I remembered...there shouldn't be any Leg Armor!!!The preview photos clearly showed the warrior wearing a torn pair of stockings! So...the maker changes the design of the set, without notifying me, the consumer, who has pre-ordered it! And no instructions provided!!!
Well, never mind, as I decided to try putting the leg armors on anyway, to see the effect. It's rather tight, again, due to my choice of a muscular body. Finally, came the High Heels Battleboots...It seems to take me forever, with alot of unwanted strengths, but still failed to put it onto the leg's metal joint!!
I decided to do some modification to one of the boot, to try to wear it...and I regretted big time! My friends, please do not do so! I tried to enlarge the hole from the boot, hoping that the metal joint will fit...and it became loose! Luckily, I did not do the same to the other leg, and by pushing the Leg armor further up the leg, created enough room for me to try on the boot again...and I finally got it in! So, the left foot was merely attached there to balance the figure...I had damaged the boot...either i buy another one (I hope i can find a separate piece), or i have to think of a way to repair the boot...
The HS of my choice for this figure has been sitting around my desk for quite sometime, and finally I can give it life...! The arm guard is designed so that the arm can be bent without restriction. And, oh, the hands...I needed to push in harder for it to fit...no more enlarging of the holes!
And don't forget to put on the scarf armor around the neck before fitting the HS. And the head band too!
This item comes with a promised hare...and an additional eagle!! It isn't featured from the preview photos! so...no complaints here!
The base looks quite good, I kinda like it...It does not take up much real estate, so should be nice to display...
update:
The holding hands are a tad too wide...it would not hold that sword firmly.
And the sword has been upgraded to metal.
Banned
Re: 1/6 Scale Lucifer Clothes Set For Fiona Valkyvia Chronicles LXF1702 12" figu
Excellent review.
Superb outfit. A must-have, for sure. Too cool...
And if it didn't fit tight it wouldn't fit tight, right?
Not to be critical here; I just cannot help but wish that you'd had a better Head Sculpt for that body, that kit, than that KT004.
And its' not that she's not lovely, it's just that, as I've often said; we all have the same damn Heads…
Anyway, again, great review!
Thanks for the great review! That is one very sexy figure! By the way, that is a Kimi KT005, not a KT004.
I have been eyeing that set for quite a while, but have been hasitant.
Does the black outfit stain?
what HS would you suggest then? I'll put it on if I have..
I'll answer that a few days later to check...thks for viewing!
Thanks for review. It's comes with bigger box than I've expected. Waiting mine as well.
You can put glue on that boot hole, let it dry and it will enough to fill a gap and tighten it.
update of preview pictures from maker:
Banned
That's a better option, I think. Much more aesthetically pleasing as a blond; it just seems to better complement the outfit, at least to mine eye. Unfortunately, that Sculpt is equally somewhat exhausted.
All of them are…
Don't you just wish that you had some new Sculpts - and, in particular, Head Sculpts made by Phicen, for Phicen - guaranteed to match the skin tones to perfection?
Meanwhile, if you've got a Skarah, that would likely fit nicely, too.
Regardless, though, your photos are outstanding and you've definitely sold this kit to me.
PS: I've had only one instance of staining - indeed, from stockings, at that - and it'd happened most immediately. So, "so far, so good" seems to me to be a good sign.
I think the KT005 works just as well. It would be nice to have a team of sexy knights in a diorama setup. Think themyscira!
But I still think, the cost of this set is too steep for a teeniweenie piece of cloth and some moulded plastic. If not for the large staircase stand, it would have been more reasonable. I would have gotten it if it were Super Duck like prices.
muscledog
Really nice set! The stockings do not convince me, they look loose, but it's just my taste.
Discussion Starter · #10 ·
updates:
1. No stain.
2. yes, stocking is a bit loose, when compared with the official photos.
found a matching chest armor...she had her limbs protected, but missed out on the rest of the vital organs!!
Thanks very much for your updated findings, brassco!
Thanks for the great and detailed review. You've helped sway my hand away from this set.
Please don't take that as a slight against your review. Your thorough and honest appraisal has pointed out several flaws in this design that the retouched promo pics don't allude to.
For me this set is VASTLY overpriced for the quality and content. The molding seems quite poor, especially on the hands and the paint job on the whole set, especially the base looks poor (and it's the poorly painted base that ups the price so much, no doubt).
I too wanted to use this on a muscular body, but it seems it's a tough fit and doesn't quite suit the physique that well.
I could forgive all these small problems, if it weren't for the quite frankly ridiculous cost of the set. $100+ for what is essentially some fabric strips and plastic bikini parts is too rich for my blood.
Thanks again for the great review. I was erm'ing and ahh'ing about getting it, but you saved me some cash.
I know I am late to the party, but does anyone know where this set might be found in stock still?
1:6 Acquisitionist
I sincerely hope she is not chafing.
Yikes.
I really like all the lucifer products but wish they weren't so limited, been trying to find Lucifer LXF1701 Wings of the Fallen for awhile now.
I luckily was still able to find one from a local hobby shop and must say this could have been cheaper. I can do without the base tbh, and adding a head could have probably made me feel better. I mean if you factor in the body and head costs, its just roughly 100USD away from the Angel Wings set. Hand Arm Sleeve Thigh Finger
Discussion Starter · #17 ·
hey! that's the same HS that i used! Yes, it could have been cheaper, if you bought it when it was just released.
I was able to score one luckily. I just stumbled upon it from a local collector shop. It wasnt in the best condition but I think I can make minor fixes.
Toy Gesture Headgear Window Black hair
1 - 19 of 19 Posts
