Well I believe I have everything now that I'll be needing to complete my Timothy Dalton Bratislava sequence figure. The leather coat from the 24 Hours Subway Hero figure arrived along with the sweater, black suit pieces, boots and gloved hands. One thing I have learned for sure from this initial kitbashing builds is that altho the parts may be listed as 1/6th scale, doesn't mean they are true to scale and interchangeable between the various bodies available.
For the Bratislava figure, I'm using a Sideshow Pierce Brosnan 007 body. First issue was removing the head only to discover Sideshow used a spring loaded pivot arrangement that wasn't compatible with my custom 1/6 Dalton head sculpt....
Next issue was the scale of the boots I wanted to use for the cello escape scene, they were a bit over scale for the body (compared to jump boots for my PTS figure).....
Third issue was attaching the hands. The black gloved hands from the 1/6 Joker Robber (Hot Toys?) figure seem to be made to fit a round wrist and the Sideshow body has a more rectangular wrist due to the wrist pivot configuration.
The leather coat isn't as loose fitting as the coat in the file but I'll go ahead and use it until I can find a suitable/custom made replacement. Also the sweater in the film is charcoal and the shirt ecru, so they will need to be dyed as well.
While not 100% accurate at this point, I think it's pretty darn close using bits and pieces from various figures....
Look forward to your thoughts, comments and suggestions!
