Head sits too high
Results 1 to 9 of 9
Thread: Head sits too high
    Aug 2016
    58
    Head sits too high
    I'm a total noob and I bought this head - 1/6 custom Scarlett Johansson sculpt head Black Widow 4.0 THE AVENGERS 2#US - on eBay.
    The head sits really high on a S09c body. You can see the very top of the metal neck peg and the neck is way too long.
    What are my options?
    I've read on the forums about warming the head and either pushing in or removing the neck socket.
    If pushing it in is a no go, if I remove it is there a replacement socket or just modify and replace the original?
    Dec 2015
    341
    Re: Head sits too high
    If you can't remove the neck peg itself, can you instead drill out the head more? Get rid of the plug inside, and drill as far as you can before breaking through the scalp.
    Then you can just use some blu-tac wrapped around the neck peg to keep the head in place and in whatever position it needs to be to look good.
    99% of my kit bashes are modified like this to get the head sitting to the right height on the neck.
    Aug 2016
    58
    For anyone interested I was able to modify the head to work.
    I used a small precision screw driver to cut the glue all around the neck peg socket. I pushed and pried slightly in to minimize risk of damaging the neck.
    I was able to pop it off the glue on the bottom once it was free all the way around.
    I then shortened the peg socket and re-inserted. I may eventually glue it but its a pretty snug fit as is.
    Apr 2011
    Texas
    284
    Quote Originally Posted by computermike View Post
    I was going to do a tutorial of this method but most people seem to prefer the drilling method so I decided not to. Glad to here you were successful in doing it.
    Dec 2015
    341
    Well I'm kind of re-thinking the drilling method... did this to one of my heads over the weekend.
    Stupidly it went straight into my hand as well but it wasn't a bad wound.
    I've drilled heads plenty of times, but this one was being really stubborn. Just couldn't get the glue on the sides to pull free and I thought one more hit with the drill would snap out the remaining bits of the plug.
    I was also rushing to get it done which is when the stupidity in my genes really gets its time to shine.
  8. #6
    Dec 2006
    Los Angeles, Calif.
    2,219
    Well, keep a hat a cap or a helmet on him and it should be o.k.
    A learning experience for the next head you work on.
  9. #7
    Jan 2006
    605
    Good that you worked it out though. But why the heck is the ball in the Phicen neck set so high? It would be good if the neckball could be adjustable.
    One is bigger than 1/6 scale, but that does'nt matter !
  10. #8
    Apr 2009
    So Cal
    337
    I usually remove the socket from the head and dremel it deeper. I replace the socket adaptor which places it farther into the head. The head will sit lower on the neck. I prefer this method over modifying the neck post. OSK sells the neck plugs if you need to replace it for either male or female bodies. Can't beat the price and free shipping.
  11. #9
    Mar 2003
    Iceland!
    3,778
    Quote Originally Posted by stevejack2 View Post
    Sorry for your loss but I can't help but laugh.
  1. Any ideas on articulating the head of a custom figure?
    By lendellprime in forum Chop Shop (bodies, vehicles)
    Last Post: 12-19-2014, 06:48
  2. Product Review | Timothy Olyphant head.
    By Binx in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 01-01-2014, 21:11
  3. Product Review | BELET 1:6 Character Head Sculpt | BLT-001
    By DeltaForceChung in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 12-13-2013, 09:55
  4. BEACH HEAD GI JOE Custom Ver. 2 with Crossbow
    By Golgo-013 in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 09-19-2009, 16:33
Head sits too high
