Mud weathering tutorial (pictures)
Results 1 to 9 of 9
Thread: Mud weathering tutorial (pictures)
    Mar 2003
    Arizona, USA
    3,809
    Ok i decided to elaborate on my technique here. It works best on vehicles and boots.
    What you will need
    Brush/Q-tip
    Small bowl
    Pure sand (cant help with the origin, my dad had a bucket of it in the garage, should be a finer grain, not a bigger grain.)
    Acryllic paint (your choice, white for snow, brown or brown/black combo for mud)
    Get a good portion of paint in your bowl. After this ligthly pour a little sand in. You will see it kinda soaks up the color. Pour the sand in until the sand doesnt soak up the color. Once this is achieved, mix. The consistancy should be a little thick, but watery, good enough that it will glop, lighlty brush on.
    Apply the mixture with brush/ q-tip lightly to the sides of the vehicles tires, the fenders, ect... Just try one spot at first. Once you see the results, you can decide on more or less.
    For boots, well i havent tried it, but i suggest a little more watery of a mix.
    While painting on the mud, stuff will drip off the brush. The process is messy, so do it some where liek a garage or out side.
    Once you have achived the desired results, dull coat the whole mudded area. i used about 2-3 coats, the stuff is pretty rock hard.
    I have used the snow technique on a diorama (sideways log) it worked well.
    I used the following brands of paint/dull cote. Use what you like, as long as its acryllic, just incase. The last 2 are craft paints, they work pretty good, avaible at a hobby lobby or a michaels probally, not sure, its my moms stuff (was).
    Testors Model Master Dull Cote
    Anita's all purpose Acryllic Craft paint (black)
    Americana Acryllic paint (light cinniamon)
    I use the 2 previous paints, as the black was 8 fluid ounces, for only $2, the little thing is somthign liek 89 cents. Might not be Jo Sonya, but it gets the job done.
    Hope this helps alot of you in your weathering.
    Attached Thumbnails Attached Thumbnails Mud weathering tutorial (pictures)-dsc01816-jpg
    "I gotta jar of diiiirt, I gotta jar of diiirt, and guess whats inside it!" - Jack Sparrow
    I brought payment. *BANG!* Look, an undead monkey! - Jack Sparrow
    Mar 2003
    Arizona, USA
    3,809
    Here is the sideways log i made
    Attached Thumbnails Attached Thumbnails Mud weathering tutorial (pictures)-gunner5-jpg
    Mar 2003
    Arizona, USA
    3,809
    close up of the jeep before an extra coat of mud
    Attached Thumbnails Attached Thumbnails Mud weathering tutorial (pictures)-jeepwet2-jpg
    Mar 2003
    Arizona, USA
    3,809
    If i try a pair of boots tonight i will post pictures. Also not heavy wear areas. If you look at my jeep thread, there is more mud in the cornors/fenders, and the back, than shown above, hence the extra coat of mud.
    the sideways log shows the snow technique (white paint on the log) its not as 3d as it should be., i think i might update is some time.
    Mar 2003
    (o)(o)
    507
    FYI,
    another great thing to try, aside from pure sand, is baby powder. Make sure you play with it a bit first to get the consistency right, but once you figure out the right balance for you to use, baby powder makes an EXCELLENT thickening an "clumping" medium to add to your paints.
    Later
    -Adam
    Roses are red, Violets are blue. I'm schizophrenic, and so am I.
    ~ Oscar Levant
    See My Trade References Here
  8. #6
    Mar 2003
    Arizona, USA
    3,809
    Cableguy: thanks for the input. Guys i would suggest his technique on uniforms/gear as it would seem to be useable in smaller scale, while the bigger stuff may be suited for vehicles lik mine, im not sure about unis.
  9. #7
    Apr 2003
    Bossier City, La.
    5,139
    You're just one bashing fool; nice work!
  10. #8
    Mar 2003
    Wilburton Oklahoma
    3,060
    hey thats a great technique
    also when I mud up a vehichle
    I use some small pebbles in it
    cause sometimes that mud can get rocky
    and I use a small brush to give it the speed streaks
    where the mud flies up the sides from the spinning tires
  11. #9
    I do something similar but I use a toothbrush. I load it up with sand/paint mixture, hold it horizontal and use my thumb to release the bristle and launch mud to the vehicle. great spaterring effects. Practice a few times before doing your vehicle.
    thetoysurgeon
  1. Mud weathering technique for vehicles
    By Pvt. Ryan HOH in forum Custom Tips & Techniques
    Last Post: 02-15-2014, 16:12
  2. Tamiya Weathering Stick
    By Chii in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 01-24-2008, 12:24
  3. Newbie bearing pictures
    By Mole in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 10-30-2005, 04:56
  4. New to the board and wanted to say Hello and post some pictures
    By corinthianleather in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 10-19-2005, 03:54
  5. Snake Eyes Custom Bash, Pictures Needed.
    By crazydragonclk in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 10-05-2005, 16:26
