Has anyone ever tried MMP Weathering Powders? http://www.ww2modelmaker.com/mmppigs.htm . If so, will they work on fabric as well as plastic?
well it looks like its based for the 1/35 products, and since most 1/35 tanks,airplanes etc.. come in plastic, i think it might be able to work on 1/6 weapons and such. but i would think it would need to be sealed. as for cloth... you can try it but i would think it would do more harm than good.
I recommend using this stuff. Works great.
http://www.hlj.com/product/tam87080
http://www.hlj.com/product/TAM87079
Weathering powders in general are great for uniforms... Its essentially chalk weathering, but the chalk is already ground up, and you dont have to do it, and waste a blender doing it....
"I gotta jar of diiiirt, I gotta jar of diiirt, and guess whats inside it!" - Jack Sparrow
I brought payment. *BANG!* Look, an undead monkey! - Jack Sparrow
Just picked up Tamiya Weathering Master & they work great.
Hey Cree82,
I used the MMP weathering powders on my OSI bash. They work great!
_____________________
Jason
Hey guys was wondering if this is the place to ask this question, does boiling the Unis in water give them that(worn out, broken in look), also heard something about soaking the Unis in Tea 4 that(darkened look) is this the way? Thanx in advance for your knowledge! Brian
"No matter how hard, how difficult, I always do what comes next."
I boiled mine in tea and then put them back on while wet and painted. worked like a charm
Along the lines of weathering, how do you take off acyrlic paint used at times for weathering?
This is the water based paint and I want to get it off some head sculpts.
Thanks
The acetone won't damage the existing HS? I am curious to know because I would like to customize some of my HSs.![]()
try rubbing alcahol ( I would test is some small spot where you won't be able to see, first.
