Recently I used Testors Dullcote on the Hasbro rubber tires without a problem, and assumed that another brand would provide the same effect. However, the other brand did not, and the chemicals I believe are reacting with the rubber. I used a Matte sealer aerosol and the tires are very sticky and will not dry.
To remedy this I used a bit of DOT 3 Brake Fluid to help remove the layer of Matte sealer. I did not soak the tire in it as usual, just poured some of the fluid on and used an old tooth brush to help remove it. Rinsed with soap and water and found that later after drying the "sticky" was still there.
Anyone had this experience and know a way to get the rest of the bad sealer off to save the tires? I hope I have not ruined them.
Thanks ahead of time
LongRange
