HOW DO YOU DO IT?![]()
helocrazed
"These things we do that others may live"
I usually run it under HOT, HOT, VERY HOT water until it is pliable enough to pop off. Sometimes you need the help of a flat screwdriver to get it started. Others prefer using a hair dryer instead. Whichever method you use, just concentrate the heat at the base of the neck.
Mark D
p.s. don't combine the hot water method and the hair dryer method at the same time...
The results are shocking!!
I boil some water in a pot then after a few minutes stick the head in the hot water fro a couple of minutes and then it pops right off; easy!!
