How to make a desert diorama
Results 1 to 16 of 16
Thread: How to make a desert diorama
    Jun 2003
    365
    Here is my how to on making a desert diorama. Its my first diorama so if you think it turned out bad then is a what not to do.
    Supplies:
    Sand
    Green "Grass" flock
    Glue
    styrofoam
    Rocks
    Paper towels
    Exacto knife
    Figure
    I started out but getting my piece of styrofoam
    I took a figure and laid him down so I could make the length about long enough to lay him down on it. Leave extra room because you will cut the board down.
    Cut off where you want it. Then break up the square shape but cutting curves using the exacto knife.
    Jun 2003
    365
    Smooth it out and get rid of little extras that are sticking up. I used a sodering (sp) iron but be careful styrofoam buring can create dangerous fumes so dont do it for long.
    This is the finished shape
    Pour glue onto the foam and spread it out using a paper towel.
    Pour the sand onto the glue and spread it out. Rinse and repeat making sure to fill in the gaps. If you want you can make certain areas have more sand on them so it looks more realistic.
    First time the sand was put on
    Halfway done
    Jun 2003
    365
    If you cant get sand into certain areas use a sand colored paint to cover up the white. Also paint can work just as well as glue if you need to keep sand in place. Make sure to shake off excess sand regularly.
    Fully sanded and painted.
    Next I laid out the position of the rocks
    Then I glued them in place but lost a rock
    Then I used dabs of glue and some flock to create grassy areas. I tried using realy grass in places but it would not stand up.
    Mar 2003
    Arizona, USA
    3,809
    Nice job!
    I use a few similar techniques, these are fast and easy to do. If you guys have time, follow this tutorial, its really easy to make one.
    "I gotta jar of diiiirt, I gotta jar of diiirt, and guess whats inside it!" - Jack Sparrow
    I brought payment. *BANG!* Look, an undead monkey! - Jack Sparrow
    Jun 2003
    365
    Next i used glue and sand to put some sand on the big rock and flock at the bottom for moss.
    All done
    My figure making use of the new diorama
    Pros: Real sand looks... well realistic. Dident cost me any money. Good base for standing shots.
    Cons: A bit too small. Lack of glue left white spots in some areas. Stand stuck together and clumped in areas.
    Lessons learned: Paint the base before hand or get colored sheet. Make it bigger. Gravel flock may not clump. Liquid startch may help grass stand up.
    It was a good first try IMHO and taught me alot. Questions, comments, hate mail?
    *edit* just found out you can get 5 pictures in a post, sorry.
  8. #6
    Mar 2003
    Arizona, USA
    3,809
    OOps,sorry for cutting in on your post there.
  9. #7
    Apr 2003
    Toronto, Canada
    145
    Looks great! I'll give it a try before school starts...I'll be a bit more ambitious though :-)
    Cheers!
    Guy
  10. #8
    Mar 2003
    Limbo
    9,329
    Awesome, S800! Thanks for the tutorial....
    Don't miss my new TOY BLOGS!===> http://toy-history.blogspot.com/----and-----http://toynewsnetwork.blogspot.com/
  11. #9
    Mar 2003
    School office
    724
    very nice tutorial...I gotta give that a try!
  12. #10
    Apr 2003
    Great white north
    101
    Thanks for taking the time for your tips on this tutorial! If I may add, using plywood, particle board, or even picture frames make for good solid bases.
    lost tourist
  13. #11
    Mar 2003
    882
    A trip to a thrift store usually turns up some great pieces of wood cheaply to use as bases.
    I usually apply a thin layer of plaster of paris, paint base first, cover in white glue mixed with water and a dash of dishwashing liquid, then sprinkle the sand over it and push in the various rocks so they stick into the base. I then repaint the sand if needed.
    Good tutorial the moss and grass are good tips. If you have trouble getting figure to stand up, I cut a piece of coat hanger wire and use that as stand behind figure, propping him up or even going up pants leg if pants aren't bloused into boots.
  14. #12
    Jul 2003
    Show me yours, I'll show you mine
    3,419
    If you really want to invest some money and get some nice realism in return, check out a train hobby store and pick up all sorts of stuff from rocks to sand to trees and grass used in making train track dioramas.
    But I like cheap... more money for those 'spensive Toy Soldier vests...
  15. #13
    Mar 2003
    882
    I get my sand, dirt and rocks from outside, really cheap. A lot of the hobby shop stuff, I find, is very expensive.
  16. #14
    Jun 2003
    10
    Well done. Take it from an old long-time dio builder.
    You've "discovered" many tried and true techniques all on your own. That's using the ol' noggin.
  17. #15
    Oct 2004
    Singapore
    24
    I will try this out when i have the next free time. I discovered this topic when i have come to the end of my leave. I have been on leave for the past week. Tomorrow i am starting work till god knows when is my next leave.
    "Risking his life to save others" FireFighters
  18. #16
    Sep 2003
    Singapura
    6,423
    Wow!!!
    Thanks for the tutorial!! It looks really good!! Thanks for sharing!
    History repeats itself, first as tragedy, then as farce. - Karl Marx
  1. Desert camo questions
    By PSCMATT in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 10-24-2005, 22:19
  2. Greek desert camo uniforms
    By basx in forum 1:1 Reference (pics, links, books, etc)
    Last Post: 10-24-2005, 22:06
  3. Finns wearing M/05 desert camo
    By basx in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 09-28-2005, 07:31
