Old 07-17-2012, 13:56
_328th_Bantar's Avatar
Hot Toys Body repair, Help needed
Hello guys, I have two hot toys bodies, one has a broken leg, right at the piece that attaches it to the hip, the other one has a broken shoulder, well the piece that goes from the shoulder to the inside of the chest is broken.
I need to transplant the legs and hips from the shoulder broken body to the broken leg-hip body.
How do I do it? I don't want to risk making another damage, they are my last HT bodies available.
Thanks!
Old 07-17-2012, 16:10
MJUMP's Avatar
1:1 Humanoid Automaton
Re: Hot Toys Body repair, Help needed
I have a lot of HT bodies and have done many part swaps and it is very easy. If you are going to swap parts it would be easier to move the arms over than the legs, First you need to remove rubber caps that hide the screws (I use a thumb tack).
Remove the 2 screws that hold the chest together, pop it open, remove broken arm, remove screw from shoulder joint, repeat for other body, replace joint. Every thing should be easy to put back together, than pop rubber caps back on.
Its more tricky replacing the hip joint, after unscrewing the thigh you have to pop it apart and theres a risk cracking it.
Hope this helped.
Old 07-17-2012, 16:21
Thanks MJUMP!
I never imagined it would be easier that way.
Old 07-17-2012, 16:22
Kouzia's Avatar
ThingsGoBetter With Rock
Here you go mate
One way to fix Hot Toys knee joint
http://jbwid.com/art72.htm
Old 07-17-2012, 16:29
Thanks Kouzia, I just took a quick look on that post because I'm working right now, are you sure that isn't only for knees?
that other URL is blocked by my corporate internet policy.
Old 08-23-2012, 16:04
And then the body I was trying to use from the waist up took a dive, land on its left shoulder and broke at that exact point.
I'm out of hot toys bodys.
My Second Bash - Medal of Honor 2010 : This is Tier 1 - Wolfpack (image heavy) old_dude33 Sixth Scale Action Figure News, Reviews, & Discussion. 70 04-13-2013 15:27
Questions - Soldier Story body against Hot Toys TT comparison Norwegian_Red Chop Shop (bodies, vehicles) 3 12-15-2010 14:55
