Page 1 of 3 12 ... LastLast
Results 1 to 30 of 70
Thread: Modelling and Painting a head
    May 2006
    York
    1,138
    Arrow Modelling and Painting a head
    Since I have been asked to post my technique for modelling and painting over here , I've cut my tutorial out from the British OSS forum and put it here .
    This shows the whole procedure from modelling through painting that I use when making a new head for one of my own figures : I'm using Fimo rather than Sculpey , because I slightly prefer it , but either will do the job .There are now various other Polymer Clays around : it's really a matter of choice which one you use , depending perhaps on which is available where you live .
    This head is obviously a One-off : but I use the same procedure when a head is intended for casting .
    The head here is a real man , a Junior British Officer serving in the later stages of WW2 in NW.Europe , and I've attempted a portrait .
    Last winter I read Peter White's moving account of his war , as a subaltern in The King's Own Scottish Borderers , fighting through Holland and Germany from September '44 until VEDay . As an account of the Sharp End , it takes some beating : " With the Jocks .." Sutton publishing .
    Out in paperback .
    I had been thinking of creating a Junior Officer for some time , and since there were several photographs of the author in the book ( he's the one on the right in the photo ), I decided to make him a real person , rather than one of my " types " .
    What follows is a largely pictorial description of how I make a head .
    I use Fimo , available in craft shops pretty well everywhere in Europe . Sculpey is an alternative , but I find it too soft for some jobs : it's a personal choice .
    The mixture , Kneaded to an even colour before starting , is four parts Dark Flesh , to one part White , the white being necessary to prevent the head coming out too translucent when finished . This mix has been arrived at after several years experiment , so you'll have to take my word for it . This is formed to a suitable blob and rammed hard onto a tile , which acts as an support throughout the process :YOU DON'T NEED A WIRE ARMATURE !
    This is then worked on with a small dental spatula : nearly all the work is done with this tool . The putty should stay in place on the tile securely :
    At this stage I check dimensions with a pair of screw compasses : about 38-40mm between the point of the chin and the top of the head . It's very easy to make the head too big as you model more material on to it , and it's worth checking again as you work . I rough out all the basic forms , referring in this case to the photos in the book :
    Everything is taking shape . I work in spasms of half an hour or so , take a break , and come back to it .
    After several sessions , once I'm happy with the way things are going , I start to put in the fine detail , using the tools you see . The brushes are for smoothing , using the Sculpey diluent as a lubricant , The white brush is quite stiff , and used for polishing out tool marks , and the brown brush is softer , for more delcate work :
    The fine finishing process takes quite a time , since it's very difficult to change things once the first firing has been done : I like to use the Fimo surface as the actual skin of the head ( not covered in paint , save for a wash ) , so it's vital to remove all blemishes before firing :you can put a patch in later , but it tends to fire as a slightly different colour , so it's best to avoid repairs if you can :
    The chopped off bristle-brush is for the stubble : you can get some very delicate surface detail using brushes .
    Before firing , I carve off the hair , since I'm going to replace it with coloured Fimo :
    Then , when you can't bear to do any more , it goes in the Baby Belling , which is perfect for firing Polymer Clays : about fifteen minutes at 125C :
    Remove from oven , allow to cool , prise off the tile . You can now carve away any unwanted parts , and add more Fimo to shape the back of the head :
    Now fire again to harden the added bits . You can fire the head many times , so long as you don't overcook it at any stage : I frequently put them in the oven seven or eight times in the course of finalising details .
    Once the flesh parts are done , I hollow out the neck and mount it on a stick with some Blutack , and add the hair , mixed to a chosen colour . The tissue paper is to stop my dirty fingers marking the neck whilst shaping the hair . The scribing and finishing of the hair involves all the tools and brushes :
    There is a pic in the book showing Peter without a hat , which I used as a guide to his hairstyle , controlling and shortening it somewhat since he's eventually going to be wearing a hat :
    Finally the modelling part is done : it looks a a bit weird at this stage , but that will be corrected by the painting:
    Now on to the Painting stage :
    First thing , before starting , is to thoroughly scrub with detergent to "wet" the head : if you don't do this ( and this also applies to resin heads ) the paint will puddle all over the place , and not stick properly .
    I generally start by using a matching brown to detail the hair , grading it down the back and sides from the coloured Fimo , and put in the eyebrows .Then I add the irises in black , establishing the " gaze " of the subject :
    I've also put in the faintest stubble , by slightly washing the beard area with a tone matching the hair colour . This is done with very dilute paint , remembering to feather the edge to avoid a sharp line .
    Then the skin tone : nothing too extreme with this subject : he's going to be in Europe in winter . This pic shows the colours I use , and they are diluted and dispersed with " acrylic matt medium " from W&N : this acts like a blender : if you can't find it , an acrylic gel drying retarder works in the same way :
    You have to chase this around for a bit with a large brush , to get it even and avoid blotches ; it's better to do several thin applications rather than one thick one . Once dry , he now looks like this :
    Now the tricky bit : the eyes . There's no getting away from the fact that you need a steady hand , and a good OO brush for this job .
    The irises are already defined in black : the shape here is very important : notice the actual shape made by the circular iris , overlapped at the top by the upper lid , and just touching the lower :
    Next , select a suitable eye colour for your subject , and fill in the iris completely , save for a fine line all round the edge . If you're feeling clever , you can add a little white to the colour and pick out the paler ring aroung the pupil and the radiating veins :
    Lastly the pupil : I use Vallejo gloss black No.861 for this : position the pupil so that it just touches the upper eyelid ( if you want a relaxed expression ) , and by repeated applications build it into a little dome :
    The more the pupil is covered by the eyelid , the sleepier the expression will be ; conversley , if there's space between the pupil and the eyelid , the subject will look alarmed ( or angry , depending on what the rest of the face is doing ).
    Here's the finished head :
    There are one or two subtle additions : a little carmine around the eyes , on the inner edges of the lids , and flushed on the ears . I've also run a fine line of carmine darkened with black into the join between the lips . The edges of the hair have been fine detailed with a tiny brush , to blend the edges where hair meets flesh . The last thing is to flood the eye with gloss acrylic varnish .
    Finally , here he is, finished , on the assembled figure : there will be another version later of him in his combat dress , but that , as they say , will be another story :
    The figure is DML , with a slightly modified DML battledress : notice the lining and hooks on the collar . The cloth badges are made for me by various friends ( thank you Peter and Rob ) , and the Tam o'shanter is made from Polyester Suede, which is a really useful fabric for 1/6 , since it has a woolen-style nap on one face , ideal for making serge uniform items .The hands are also modelled in Fimo , and attached to DML wrist pins with superglue .
    The webbing belt is scratchbuilt using Richie Elbourne's scale etched brass sets ( britishbuckles@ntlworld.com ), and the holster is DML , slightly modified.
  2. #2
    Sep 2006
    13
    thanks for posting your techniques. great work!
    Karma is a funny thing!
  3. #3
    Jun 2006
    Ridgecrest, California, USA
    751
    Awesome Tony, admins please make sure we archive this thread in the tips section.
    Mik
  4. #4
    Feb 2004
    Lion City
    2,744
  5. #5
    Aug 2004
    1,043
    Your work is fantastic!! It's very interesting to see the different techniques that people use. Thanks for sharing.
  6. #6
    Jul 2005
    Natchez, MS
    452
    Wow!!! Totally amazing. Excellent work.
  7. #7
    Feb 2004
    Lion City
    2,744
    I just noticed the hands are also good
  8. #8
    Mar 2003
    The Great White North
    11,749
    What a fantastic resource. Archived!
    Maintiens le Droits
  9. #9
    Jan 2004
    62
    Really impressive!
    I sculpt heads myself so I can say that this is a first class work!
  10. #10
    Oct 2006
    NL
    3
    Impressive indeed. Thanks for sharing !
  11. #11
    Sep 2006
    Spokane Valley, Wa
    1,578
    Thanks a bunch for sharing. I found your tutorial before but lost is by accident, so double thanks. Awesome work!!!
    Trade refs.
    FT/FS page.
    Dog training: $50K, Collar: $35, The look on your face when I drop my leash...Priceless
  12. #12
    Aug 2006
    32
    Beautiful and delicate work here...I have a few questions. Do you seal the paint job after your finished? how well do those liquitex paints hold up? and are there any paints that you'd recommend? Like for example, are there any that are more durable than others?
  13. #13
    Mar 2003
    Smallest State in the union
    1,275
    Great tutorial Tony. If I may I have a question. Do you use beads for the eyes, and if so what size? I've been fooling around with a few sculpts myself, and find the eyes the most difficult to execute convincingly. Thanks!
    ''It is man's perdition to be safe when he ought to die for
    the truth"
  14. #14
    Jun 2006
    751
    John, I hope Tony doesn't mind, I copied his answer from a thread on the OSS forum:
    " I leave the eye-sockets empty for the first firing , then do the back of the head and hair , then fill the empty sockets with white fimo to complete the eyes : it takes some careful shaping to get the curvature just right .
    The expression in the eyes is completely defined by their shape : pull faces in a mirror and you will understand . That shape is actually easier to model with an empty socket , since you can get your tools inside as well as out .
    I have tried inserting beads for eyes in the past , but it's actually simpler this way : you don't have to stick with whatever the shape of the bead is , which gives you more flexibility."
    Mik
  15. #15
    Mar 2003
    1,275
    Thanks Mik!
    the truth"
  16. #16
    Aug 2005
    Milwaukee, WI
    242
    Dear Tony,
    First I would like to thank you for being so open and generous with your technique. Second, could you please clarify one of your instructions? I am not sure hwat you mean by this sentence:
    "First thing , before starting , is to thoroughly scrub with detergent to the water-based acrylic to "wet" the head"
    Do you mean that you first wash the head before you apply the detergent? Or do you add detergent to the acrylic? Or do you wash and then do a 'wash' of acrylic like a primer?
    Thank you.
  17. #17
    May 2006
    York
    1,138
    Johnny . it's a typo that somehow got left in ! Sorry , I'll edit it .
    What I meant was to scrub the Fimo head with detergent , and rinse , before starting painting . If you are using a water-based paint , it's got to "wet" the surface to go on properly , and detergent is the easiest solution .
  18. #18
    Aug 2005
    Milwaukee, WI
    242
    Thank you, Tony! I am making a head and painting it for the Santa contest. It's my first head sculpt! Yikes!
  19. #19
    May 2006
    York
    1,138
    Good Luck !
  20. #20
    Mar 2003
    Texas
    5,653
    I truly admire your work and your generosity in sharing your techniques with us, Tony
  21. #21
    Sep 2005
    Australia
    259
    Straight from the expert's mouth... awe-inspiring... thanks Tony... I'll try to follow your lead...
    "The only thing necessary for the triumph of evil is for good men to do nothing."
  22. #22
    Jun 2007
    LA, California, USA
    361
    that really helped, thank you Tony
  23. #23
    Jun 2007
    LA, California, USA
    361
    after trying it out, FIMO is so much easier to use, it's harder and easy to sculpt. Tony thank you again!!
  24. #24
    Jul 2007
    Avord, France
    159
    Thanks Tony, very nice and interesting tuto
    I've got a question : how do you proceed to put the head on the Dragon figure body?
    Keep up the good job, very realistic head!
    Fall out gents!
    Pascal
  25. #25
    Jul 2007
    40
    thank you very much for sharing you should get a job with dragon awsome work
  26. #26
    Mar 2009
    Nebraska
    15
    Re: Modelling and Painting a head
    This is most handy! Thanks!
  27. #27
    Apr 2009
    2
    I'd also like to know how you go from the clay sculpt to putting the head on the body? Do you use the claysculpt or make a resin cast of it?
    How do you get the sculpted head onto the body?
  28. #28
    May 2006
    York
    1,138
    That depends : for the figures in my own collection , I use the original Fimo head.
    But many of those get cast into resin as well , so I can sell the copies., but of course I keep the Fimo original once it's been cast .
    The neck is hollowed out anyway as part of the finishing, then I fit it onto a new neckpost which I add to the body: most of my bodies ( DML largely , sometimes Medicom ) are modified somewhat anyway.
    Resin heads don't generally fit commercial neck plugs , which are intended for bendy vinyl Heads.
    You have to get away from the idea that all heads should be interchangeable as a push fit : be creative , make your own plugs from epoxy putty or Sculpey, and modify the bodies until they work.
    There is inevitably less movement available, but you don't really need that anyway , unless you want to play with them like GI Joe.
    Here's how most of my Heads are fitted : a Sculpey neckplug , fitted to a modified DML neck:~
    And I hold them in place with office tack rather than glue : I might want to change them later!
  29. #29
    Mar 2009
    Louisiana
    53
    Tony,
    have enjoyed reading your tutorial and checking out some of your custom works. It's nice to find a forum like this one where there are so many talented artists willing to share ideas and give tips like this one. Thanks so much!
  30. #30
    Apr 2006
    Paris
    178
    Thank you very much Tony for this good explain.
  1. Modelling and Painting a head
    By Tony Barton in forum Sixth Scale Action Figure News, Reviews, & Discussion.
    Last Post: 10-03-2006, 21:50
KGHobby...Click Here!
Vlad's Toys...Click Here!
BlackOps Toys...Click Here!
HobbyLink Japan...Click Here!
The ToySource...Click Here!
Timewalker Toys...Click Here!
ToyWiz...Click Here!
Nouveau Toys...Click Here!
Hot Toys...Click Here!
